Unity Connection 2.1 Reporting
Nov 12th, 2008
Customer is asking how to get a report of users who have not yet set up their mailboxes.
Anyone know of a way to do this? It appears that reporting is somewhat limited on UC 2.1
rob.huffman Wed, 11/12/2008 - 06:25
Hi Clifford,
This may help in this search;
Connection User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a Windows-based remote database administration tool available on the Cisco Unity Tools website. CUDD allows you to export specific information about users to a file that can be viewed or imported into another application, such as a database utility or Microsoft Excel. When the data is exported, the tool automatically creates a header row that lists the data type found in each column of the output, for ease of import into other programs.
For more information and to download the tool, go to the Cisco Unity Tools website at http://www.ciscounitytools.com and click CUC 2.x Tools.
From the Help Notes;
Requirements/Special Notes
This version of User Data Dump runs on Windows XP/2000/2003 or Vista.
***This version of User Data Dump only works with Unity Connection 7.0(1) or later.
You must enable the ODBC proxy service on the Unity Connection server and attach to the database using an account enabled for the remote database access role. See the next section for details on this.
***Full support for this tool (CUDD) is not available until UC 7.0 but it is partially supported in 2.x. Have a look at this thread from August of this year where Unity design Master Lindborg weighs in on this :)
Hope this helps!
