Giuseppe Larosa Wed, 11/12/2008 - 11:49
  • Hall of Fame,
    Founding Member
Hello Rahul,
the suggestion is to use a hierarchical approach with an access layer and a distribution layer on each site.
At the access-layer you can use C3750 with 48ports each if users are in different floors.
For the distribution a pair of C4506 should be fine.
Hope to help
Giuseppe
Joseph W. Doherty Wed, 11/12/2008 - 19:17
The number of ports isn't an issue unless you hope to connect to just one device. Which devices you might best use depends how much performance you believe you need to offer to your connected hosts and what features you're looking to implement. You might try this tool, http://www.ciscowebtools.com/productadvisor/, and look at switches and routers.
