QoS for VoIP
Nov 12th, 2008
Guys, How are you?
I have two routers that are configured to support the VoIP service.
The VoIP calls are working, but sometimes I'm facing the quality problem, same with QoS applyed. I don't understand why this happen!
I think that with configurations, the voice traffic was priority over others traffics.
Should somebody help me?
I will go to post the configuration below
END A
class-map match-any gold
match ip rtp 16384 16383
match ip dscp ef
match ip precedence 5
class-map match-any silver
match access-group name sinalizacao_voz
policy-map 1M_8ch
class gold
priority 120
set ip dscp ef
class silver
set ip dscp af31
bandwidth 8
class class-default
fair-queue
random-detect
set ip dscp default
interface ATM1/0.2 point-to-point
bandwidth 1024
ip address
no ip route-cache
pvc 5/107
protocol ip
vbr-nrt 1242 1242
encapsulation aal5autoppp Virtual-Template102
interface Virtual-Template102
bandwidth 1024
ip unnumbered ATM1/0.2
ip tcp header-compression iphc-format
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
service-policy output 1M_8ch
ip rtp header-compression iphc-format
ip access-list extended sinalizacao_voz
permit tcp any range 1719 1720 any
permit tcp any any range 1719 1720
permit tcp any any range 11000 11999
permit tcp any range 11000 11999 any
permit tcp any any range 2000 2002
permit tcp any range 2000 2002 any
permit tcp any any range 8001 8002
permit tcp any range 8001 8002 any
END B
match ip dscp ef
class-map match-any video
match access-group name video_conf
policy-map 1M_8ch
class gold
priority 120
set ip dscp ef
class silver
set ip dscp af31
bandwidth 8
class class-default
fair-queue
random-detect
set ip dscp default
policy-map 512k_8ch
class gold
priority 100
set ip dscp ef
class silver
set ip dscp af31
bandwidth 8
class class-default
fair-queue
random-detect
set ip dscp default
interface Serial0/1.1 point-to-point
bandwidth 1024
ip address
no cdp enable
frame-relay interface-dlci 21 ppp Virtual-Template1
class 1M
bandwidth 1024
ip unnumbered Serial0/1.1
ppp multilink
Note: The link was checked and I looked okay it.
smahbub Tue, 11/18/2008 - 09:26
  • Silver, 250 points or more
The primary goal of Quality of Service (QoS) is to make network service better and more predictable by providing dedicated bandwidth, controlled jitter and latency, and improved loss characteristics. QoS achieves these goals by providing tools for managing network congestion, shaping network traffic, using expensive wide-area links more efficiently, and setting traffic policies across the network.
Troubleshooting Quality of Service for VoIP:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/voice_troubleshooting/old/vts_qos.html
ayo.monehin Wed, 11/26/2008 - 04:58
Since your voice is travelling over the WAN, I was just wondering if you've got some sort of agreement with your service provider.
You can mark your traffic all you like, but if your SP aren't in synch with you then you might run into trouble.
Another thing worth mentioning is the fact that if you let your traffic "burst" above the agreed rate, your traffic (voice and data) is likely do be dropped sometimes regardless of the QoS marking because of the discard eligibility.
I would suggest you explore using Traffic Shaping.
