Normal Amount of Discards
Nov 12th, 2008
What would you guys consider to be around a normal amount of Transmit Discards on a switch?
I'm asking this because we use solarwinds and under High Errors & Discards it's showing pretty much all my HP Thin Clients, Computers and some printers with discards over 500,000,000!!!
I would think that is not normal at all!!
But we have a stack of 7 switches and almost every port on all the switches are like that.
Any ideas?
ropethic Wed, 11/12/2008 - 06:53
  • Silver, 250 points or more
Check to see if jumbo frames is enabled. Sounds like if jumbo frames are enabled on devices they are being dropped on the switch ports.
show system MTU
500M discards is not normal
What version are you running? Platform?
readymixed1 Wed, 11/12/2008 - 07:00
Show System MTU:
System MTU size is 1500 bytes
System Jumbo MTU size is 1500 bytes
Routing MTU size is 1500 bytes
Cataylst 3750 (stack of 7, 3 which are 10/100 and 4 which are 10/100/1000)
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(44)SE2
johnlloyd_13 Wed, 11/12/2008 - 07:37
  • Blue, 1500 points or more
that number is insane! test your cables and replace to test it. you might also want to check and correct duplex and speed settings.
readymixed1 Wed, 11/12/2008 - 07:59
I took 3 ports and check them. They are at Full Duplex Speed 100
So i set speed and duplex to auto and i'll see what happens.
Whats strange is it is all the ports on all the switches pretty much.
The network person before me set every single port to the following:
storm-control broadcast level 20
spanning-tree portfast
spanning-tree bpduguard enable
Could this be somewhat of a problem? Because we have through the building 3com 8 port switches that have multiple devices plugged into them.
Although I still need to figure out what is causing all the problems.
I'm sure some of the cables are old and we are in the process of switching them out but I just find it strange that almost all the ports report a high transmit discard (this is through Solarwinds).
I am in the process of setting up IDFs (1 for up stairs, 1 for the front of the building and 1 for the back of the building). Then running the IDfs back to our server room and into our 3750G's.
But back to the high discard packets and also the spanning-tree portfast on all the ports.
readymixed1 Wed, 11/12/2008 - 08:56
Another note,
Would you disable Flow Control on your ports?
johnlloyd_13 Wed, 11/12/2008 - 18:21
is the report you received from solarwinds set at 24 hours or 7 days interval? how about polling of your devices? you might also want to check your NMS settings.
