11-12-2008 07:09 AM - edited 03-04-2019 12:17 AM
Hi...!
i have large intra network of switches in my organization. one of my parent switch reports error ....the error causes the layer 3 communication hanged for 2 or 3 minute but layer 2 communication wasn't stop and all my child switches were working properly. please see the exact message from SNMP server:
Nov 12 17:22:42 10.X.X.X 329: 000332: .Nov 12 17:22:31: %RTD-1-ADDR_FLAP: GigabitEthernet0/1 relearning 5 addrs per min
Nov 12 17:45:31 10.X.X.X 330: 000333: .Nov 12 17:45:21: %SYS-2-WATCHDOG: Process aborted on watchdog timeout, process = Virtual Exec.
Nov 12 17:45:31 10.X.X.X 331: -Traceback= 1EACC0 1EC568 1E5A6C 22D65C 22B4D4 22B69C 1F59A0 223340 223AC8 223BA4 1750D0 180CDC 1EB510
i explorer all causes but didnt understand....i need expert's help.
regards
11-12-2008 08:21 AM
zargham
I am not sure what the exact problem is. But a Traceback such as is part of your output is a sign of a software problem. I would suggest that you try upgrading to a more recent version of code and see if the problem is resolved in the newer code.
Rick
11-12-2008 09:58 PM
Hi Rick;
Thank you very much for you reply.
Please see the version of software:
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
Pad16_Fiber_Switch uptime is 12 hours, 58 minutes
System returned to ROM by reload
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3508G-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID FAA0448F0PA, with hardware revision 0x01
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
8 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:04:4D:8E:BB:00
Motherboard assembly number: 73-3985-07
Power supply part number: 34-0940-01
Motherboard serial number: FAA044701CZ
Power supply serial number: APQ0439029D
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3508G-XL-EN
System serial number: FAA0448F0PA
Configuration register is 0xF
this switch has 15 child switches. and i checked by viewing topology that there is no loop. it means ADD_FLAP error should not occur.
waiting for your reply;
regards
