1811 correct image
Hello guys,
I am confused about 1811 Router images.
I need an IOS that supports zone-based firewall.I am running (C181X-ADVIPSERVICESK9-M), Version 12.4(6)T11, I am able to create zones and class-maps but couldnt link zone pair to a class-map. The system says unsopported.
Can somebody tell what image to download from cisco.com because I checked and didnt find IP advanced security image for that series routers.
rvr
hadbou Tue, 11/18/2008 - 15:13
The cisco IOS zone-based firewall is supported in the image that you are using right now which is (c181x-advipservicesk9-mz.124-6.T11.bin).Think there might be some error in the configuration you have done.So check the configuration of zone based firewall using the configuration guide present in the url below:
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008060f6dd.html#wp1206417
Also use the cisco feature navigator present in the uel below for finding the featuress supported nased on the IOS used:
http://tools.cisco.com/ITDIT/CFN/Dispatch?showAllSoftware=true
