How to get DEVICENAME parameter in CME
Nov 12th, 2008
I am trying to get de #DEVICENAME# parameter using a url like this:
http://10.0.0.1/service.php?device=#DEVICENAME#
but doesnt work.
I know that this work fine in callmanager full, but does it work in callmanager express ?
I am using Unified Communications Manager Express 7.0
tstanik Tue, 11/18/2008 - 09:33
  • Bronze, 100 points or more
Use this command to verify which phone firmware is installed on a particular ephone. The DeviceName includes the MAC address for the IP phone.
Router# show ephone phone-load
toshiosakata Tue, 11/18/2008 - 09:52
hi tstanik,
Thank you for your reply.
Let me explain better:
I created a XML service and the url is
http://10.0.0.10/service.php?device=#DEVICENAME#
So, when I access this service through the ip phone (7960) I expect to get it devicename.
I have tested this in the callmanager 5.0 and works. But in the callmanager express doesnt work.
I need to identify who is the device that is accessing the service.
stephan.steiner Wed, 11/19/2008 - 02:26
  • Silver, 250 points or more
Have you checked what happens if you add a regular service url to the phone on the cme and then have the phone make that call.. do you get any query string or nothing at all?
Nicholas Matthews Fri, 12/12/2008 - 18:24
  • Red, 2250 points or more
A little late, but thought you should know:
I just filed/resolved a bug with this. You can track it via CSCsv95576
It should be fixed in 12.4(22)T1 and 12.4(20)T2
