WLAN design wireless location appliance
Nov 12th, 2008
We are planning to implement a wireless network with Cisco LWAP 1240AG AP's with Cisco AIR-ANT4941 antenna.
I understand that you should have AP's around the inside edge of the building spaced between 8-10 metres depending on the survey and then work inward with omni-directionsal antenna like the AIR-ANT4941.
Should the AP's around the edge have directional Antenna's rather than the 4941
Mark
Overall Rating: 3 (1 ratings)
jeff.kish Wed, 11/12/2008 - 11:09
  • Silver, 250 points or more
There's no right or wrong answer to this. As long as you specify in WCS which antennas you're using, you'll be fine. I would advise sticking with the 4941s, because patch antennas are usually strong enough to cover a lot of ground, and that can result in channel overlap.
As long as you can create a good channel scheme, do whichever you prefer.
mark.cronin Wed, 11/12/2008 - 11:27
Jeff
Thanks, you mentioned channel scheme:-
In the USA the non over lapping channels for 2.4ghz b/g are 1,6,11
In the UK / Europe they are 1,7,13
I have found that a lot of installs in the UK are using 1,6,11 do you know why?
Also I have been looking at other wireless vendors and they are promoting the Channel blanket (all APs on same channel) approach rather than cell based scheme. have you had any experience wirth the channel blanket systems?
Are Cisco going to adopt this approach?
Mark
jeff.kish Wed, 11/12/2008 - 14:14
Hi Mark,
Channel 1, 6, and 11 are just about as non-overlapping as 1, 7, and 13. There's an insignificant amount of overlap, so it's just as plausible of a solution, even in Europe. I honestly don't know why you wouldn't use the extra channels to eliminate the minor overlap - every bit helps.
The "channel blanket" or "virtual cell" WLAN design philosophy is rapidly spreading. Cisco maintains that it's a standards violation and I've heard no talk of them purchasing the not-to-be-named company or of them adopting the same design philosophy. I sincerely hope that they do one of the two soon, however, because it's very good design that's difficult for Cisco to compete against.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
