site to site with 501
Answered Question
Nov 12th, 2008
Long time reader, first time post.
I am trying to create a site-to-site tunnel between two 501 PIXs. I have rummaged through multiple forums and Cisco white papers and I cannot create this tunnel. Any help would be appreciated.
I have done a debug crypto ipsec and debug crypto isakmp. I get nothing on both sides…just a cursor blinking back at me.
Attached are my configs.
thanks in advance,
Correct Answer by ajagadee about 8 years 3 months ago
Hi David,
Couple of things:
1. Make sure that you have logging enabled to see the debugs.
Logging on
Logging Buffered Debugging
2. Also, where are you initiating the IPSEC Traffic. It has to be from a host behind the Pix 501. You cannot initiate IPSEC Traffic from the pix itself.
Arul
*Pls rate if it helps*
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/gl.html#wp1028090
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Wed, 11/12/2008 - 09:24
Hi David,
Couple of things:
Logging on
Arul
manilla77 Wed, 11/12/2008 - 09:59
I was just getting ready to reply to my original post. I think by posting, it scared the VPN tunnel into working. Not sure what I did, but its working. I think possibly clearing crypto ipsec sa and clear crypto isakmp sa helped even though I had tried this before. Thank you very much for the quick response.
Case closed!
