Is this CSCeb51407? - Device sensed, but collection failed -
Answered Question
Nov 12th, 2008
  • Blue, 1500 points or more
RME4.2
Am I right that this is caused by a bug in Entity-MIB for cat3550 in 12.1(13)EA1c (CSCeb51407) and the only workaround is to upgrad to 12.1(19)EA1 or higher? I want to confirm this because there are only a few hundred devices affected...
===CSCeb51407IC_Server.log===
[ Wed Nov 12 18:22:53 MET 2008 ],INFO ,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,271,DP time is
10 seconds for 172.29.241.40
[ Wed Nov 12 18:22:53 MET 2008 ],ERROR,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,361,Exception f
or device 172.29.241.40 is
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionController.java:356)
at java.lang.Thread.run(Thread.java:595)
Caused by: com.cisco.nm.xms.xdi.ags.system.CollectionFailedDeviceSensed: java.lang.NullPointerException
at com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatIOS.ContainmentAGI_ENTITY_Mib_Non_Modular.populatingTheChassis(Containm
entAGI_ENTITY_Mib_Non_Modular.java:258)
at com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatIOS.ContainmentAGI_ENTITY_Mib_Non_Modular.g$eval(ContainmentAGI_ENTITY_
Mib_Non_Modular.java:112)
at com.cisco.nm.xms.xdi.ags.ContainmentAGI.g$eval(ContainmentAGI.java:21)
at com.cisco.nm.xms.xdi.SdiEngine.initAndEvalAGIs(SdiEngine.java:383)
at com.cisco.nm.xms.xdi.SdiEngine.request(SdiEngine.java:309)
at com.cisco.nm.xms.xdi.SdiEngine.getDevRepr(SdiEngine.java:302)
at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionController.java:266)
... 1 more
[ Wed Nov 12 18:22:53 MET 2008 ],ERROR,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,368, Collection
failed but sensed the device : 1406
[ Wed Nov 12 18:22:53 MET 2008 ],INFO ,[Thread-36],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,207,Checking ..
[ Wed Nov 12 18:22:53 MET 2008 ],INFO ,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,566,Trap Starte
d first
[ Wed Nov 12 18:22:53 MET 2008 ],INFO ,[Thread-26],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,574,result =Dev
ice sensed, but collection failed date=Wed Nov 12 18-22-53 MET 2008
Correct Answer by Joe Clarke about 8 years 8 months ago
Yes, you need to be on 12.1(19)EA1 or higher for 3550 switches. There is also a bug that has similar symptoms which affects newer 3550 code (late 12.2), but it is fixed in RME 4.2.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 11/12/2008 - 10:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Martin Ermel Wed, 11/12/2008 - 10:47
thanks for this quick response!
- it seems to be time to forward this information and leave this place ... :-)
