Trunk Port Config
Nov 12th, 2008
I have 2 2960 switches. I am doing VLAN's and I am trying to configure my trunk ports. On my port I am trying to enter "switchport trunk encapsulation dot1q" but the switch will not take the command. If I enter "switchport trunk ?" the encapsulation option is not there. Is this a feature which is only available on layer 3 switches?
Jon Marshall Wed, 11/12/2008 - 13:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The 2960 switch only supports 802.1q encapsulation ie. it doesn't support ISL encapsulation.
Because it only supports dot1q you don't get the option to configure it.
Jon
