VPN cannot connect
Nov 12th, 2008
Hi.
I want to allow a PC to establish a VPN to another site (a 3COM TPX).
The PC is using Windows standar connection. It can establish a VPN directly, but when I connect this PC behind my ASA 5520 & 5510, the VPN does not work.
I have this scenario.
Internet->ASA5520->ASA5510->LAN
In the ASA 5520 I add this rule:
Secbride incoming source a.b.c.d destination ANY, service IP, accion PERMIT.
Secbride is the segment between the 2 ASAs.
The second ASA 5510, there is allowing everthing, it is just like an anti-X.
Somenthing I missed??
help please?
I tried this rule in
sadbulali Tue, 11/18/2008 - 09:38
  • Bronze, 100 points or more
Cisco VPN Clients are unable to authenticate when the X-auth is used with the Radius server.The problem can be that the xauth times out. Increase the timeout value for AAA server in order to resolve this issue .We will be able to help you better if you can provide the excat error message you are getting so that we can fiond the reason for the error.
For example:
Hostname(config)#aaa-server test protocol radius
hostname(config-aaa-server-group)#aaa-server test host 10.2.3.4
hostname(config-aaa-server-host)#timeout 10
