PROBLEM: CUE Administration over EzVPN
Hello All,
I currently have an 1861 w/ CME and CUE.
Vlan 2 is voice
Vlan 3 is data
EzVPN Remote (NEM)
Scenario 1: VPN is NOT active
When any pc attempts to browse to the CUE administration page, it will not load.
However, when I remove the 'crypto ipsec client ezvpn BGAN inside' syntax from the vlan 3 SVI the PC can ping and thus the administration page will load.
Scenario 2: VPN IS active
CUE administration page will load normally and I do not have to remove any syntax.
I opened two TAC service requests and neither agent is aware of a known bug which is not helpful for me, so I am hoping to get feedback from somebody on this forum that has experienced the same issue.
Below you will find a snippet of the config.
Thanks again for the help!
NOTE: CUE is working and vmails can be left, I just cant hit the administration page.
I wonder if a PBR policy will fix this issue.
interface Integrated-Service-Engine0/0
ip address
service-module ip address
service-module ip default-gateway
interface Vlan2
ip address
h323-gateway voip interface
h323-gateway voip bind srcaddr
interface Vlan3
ip address
ip route Integrated-Service-Engine0/0
ip route FastEthernet0/0
interface FastEthernet0/0
description Internet
ip address x.x.x.x x.x.x.x.x
duplex auto
speed auto
crypto ipsec df-bit clear
