CM TSP Version
dcscuba23 Wed, 11/12/2008 - 16:19
One way would be to log into CM and go to " Application" and then download the "Cisco Telephony Service Provider" Plugin. When you click on the executable on your machine, it will tell you what the TSP version you will be installing is. You can then cancel the install.
* Please rate helpful posts.
Rob Huffman Thu, 11/13/2008 - 06:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Daniel,
This is a good reference;
Supported Version Combinations for Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified Communications Manager
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html#wp51076
Hope this helps!
Rob
