2821 Voice Gateway
Answered Question
I need to add more DSP resources to my voicegateway. I currently have 1 PVDMII 32 with 2 16 channel dsp ( I am guessing on the motherboard). My question is can I just order another PVDMII 32 and add this to my mother board? Or do I need some type of NM to do this?
dfwdls-2821-01#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 8.4.1
Max signal/voice channel: 16/16
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 7
Voice channels allocated: 0
Credits used: 0
dsp 2:
Max credits: 240
Signaling channels allocated: 16
Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
dsp 1:
Max credits: 240
Credits used: 0
dsp 2:
Max credits: 240
Credits used: 0
DSP groups on slot 2:
This command is not applicable to slot 2
0 DSP resource allocation failure
dfwdls-2821-01#sh inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V04, SN:
NAME: "One port T1 voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "On
e port T1 voice interface daughtercard"
PID: VWIC-1MFT-T1= , VID: 1.0, SN:
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot
2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SI
MM with Two DSPs"
PID: PVDM2-32 , VID: NA , SN:
Correct Answer by allan.thomas about 8 years 5 months ago
The ISR 2821 has three onboard PVDM slots, therefore it is possible to add a 2nd or 3rd PVDM2-32 if required.
Your 'show inv' only indicates the single PVDM, therefore you should be able to add two additional PVDMs
Hope this helps.
Allan.
Pls rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
allan.thomas Wed, 11/12/2008 - 15:33
  • Blue, 1500 points or more
Hope this helps.
Allan.
