csm -s generating CSR
Nov 12th, 2008
I am using the CiscoView Device Manager and trying to create a CSR to send to Verisign. The wizard is called Certificate Trustpoint setup. On step 4 it asks to specify the CA certificate PEM file from the client machine or copy and paste the PEM certificate.
I don't have a PEM file from a CA (Verisign) do I really need to have one to create a CSR and if so why? I have not needed this on other systems.
hadbou Tue, 11/18/2008 - 07:29
  • Bronze, 100 points or more
To generate a CSR, you first configure a Certificate Trustpoint. You then specify the attributes and enrollment method for the corresponding SSL certificate.
perform the following steps to generate a CSR.
1) Specify a Trustpoint and RSA key pair
2) Configure the SSL certificate's attributes
3) Configure the SSL certificate's enrollment method
http://www.cisco.com/en/US/docs/net_mgmt/ciscoview_device_manager_web_vpn/1.1/user/guide/wizards2.html#wp1209508
