supervisor engine redundandy Cat 6509 (active module)
arturo.reyna
Hi everybody:
I have two catalyst 6509 with supervisor engine redundandy; first one has the module 5 active and the second has the module 6 active.
Is there a way to change configuration to set wich module will be active? I want to configure the same module active in both boxes.
Thank you for your comments.
Edison Ortiz
Whichever Supervisor boots up first will be the active one. There isn't a command to specify a priority for this.
With that say, you can manually force a switchover if you want the current standby Supervisor as active.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
