CALL BLOCKING
Nov 12th, 2008
Guys,
Need your sugestions to block a specified country call on my voice gateway.Below is my configuration. Pls give in your ideas.
voice translation-rule 91
rule 1 reject /^71001191/
voice translation-profile block_india
translate called 91
dial-peer voice 710 pots
call-block translation-profile incoming block_india
destination-pattern 710T
translate-outgoing called 91
direct-inward-dial
port 0/1/0:23
allan.thomas Thu, 11/13/2008 - 01:12
  • Blue, 1500 points or more
I'm assuming you are attempting block outgoing called party numbers starting ^7 from ?
If this is the case then you should apply the call-block translation-profile incoming block_india on the incoming call-leg specifically the VoIP dial-peer from CallManager not on the pots as this will be the outbound call-leg:-
dial-peer voice 100 voip
call-block disconnect-cause incoming invalid_number
Hope this helps
Allan.
Pls rate helpful posts.
gopinath.j Thu, 11/13/2008 - 23:06
Hi Allan,
Thanks for the info. Little brief with diagram.
Calling no 906821 to called no 71001190-6823 should be allowed.
Calling no 906821 to called no 71001191-6822 should be not allowed.
Current configuration also given in the diagram.
iptuser55 Fri, 11/14/2008 - 01:51
  • Silver, 250 points or more
You can use a COR list for outgoing blocking on router A so it is blocked at source.
allan.thomas Fri, 11/14/2008 - 01:53
Can you clarify a little further please, it is not clear what telephony system the calling party 906821 is connected to. I don't belive it is CME as the diagram would show it connect to the gateway, so is it a PBX or CUCM?
Ideally it would be practical to block the calls nearer to the source, rather allowing the call to transverse the WAN using value bandwidth before being dropped.
If the calling party is connected to CUCM then you can implement calling restrictions using route-patterns in partitions assigned specifically to this DN's CSS.
Alternatively if the gateway is connected to a PBX, then you should configure the block translation profile on the incoming trunk call-leg. Is port 1/0:15 the PBX trunk port?
translate called 91
dial-peer voice 90 pots
destination-pattern 90T
forward-digits all
port 1/0:15
Calls to the called-party number 71001190 will not be be matched against the call-block translation-profile rule 1, and will be proceed to the outgoing VoIP dial-peer 710.
You will also need to ensure be aware that pots dial-peers strips the digits which are matched.
In your case, the pots dial-peer in location A will strip digits 90 for called number starting 90, there calls to 906821 will be 6821 is this desired? In not make sure that you forward-digits all.
Hope this helps
Allan.
