ATA186
Nov 12th, 2008
I am having 4 numbers of ATA 186 out of which 2 had been configured on UCM 6.0 FAX is connected to one of the ATA and a analog phone is connected to another ATA. The problem is
When someone calls from outside sometime the phone/Fax rings, and sometime they get the message “please check the number, it does not exist “ and this is intermittent, that is it 15 to 20 minutes.
The internal calling is working fine [extension to extension calling]
I have Enabled debug on the voice gateway, at the time when there is problem, call is coming up to the router and it says “Unallocated/unassigned number”.
please suggest.
mchin345 Tue, 11/18/2008 - 11:18
  • Silver, 250 points or more
Add "no ccm-manager fax protocol"
Do show mgcp. It will give all the configs we need to check for.
Get the following debugs for the failed call.
-debug voip ccapi inout
-debug voip vtsp all
-debug voip vsm all
-debug mgcp packets
From Callmanager
-detailed ccm trace
