High Bpdus (MRecords) sent 14204303, received 44682
Nov 13th, 2008
I am running MST01 on my network.all the GIG ports are getting connected to leaf switches like 3560 and 4948.when I do the command
"show spanning-tree mst 1 detail" I see that BPDU received on port 3/44 is very high than any other ports .Iam doign this command on the root bridge .
what could be cuasing these BPDU recieve to go high on the root bridge
Giuseppe Larosa Thu, 11/13/2008 - 01:49
  • Hall of Fame,
    Founding Member
Hello Ajai,
it looks like out that port there is a device that doesn't agree on the root bridge id.
verify the MST region config on the device because if a parameter is mismatching both devices think to be in different regions
OR the device is root bridge for one MST instance
Hope to help
Giuseppe
athambi Thu, 11/13/2008 - 02:26
this is the config of MSt on root
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-999 priority 12288
spanning-tree mst configuration
instance 1 vlan 1-999
spanning-tree mst 0-1 priority 8192
The below is the confg for the leaf switch
spanning-tree vlan 1-999 priority 61440
spanning-tree mst 0-1 priority 61440
Giuseppe Larosa Thu, 11/13/2008 - 12:04
  • Hall of Fame,
    Founding Member
Hello Ajai,
MST configuration includes other parameters that I don't see here.
the region name and the revision number for example have to match.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/spantree.html
you can also have a look at access switch log with sh log and see if there are STP events
Hope to help
Giuseppe
