ACE4710 and RDP Load Balancing
fsteininger
I have configure "RDP Load Balancing" as explained in the Software Version A3(1.0) manual.
Users claim that they do not reconnect to the RDP session after a quite short inactivity time !
What are the default RDP "sticky" timers and where can I see these values?
How can I modify the timers that allows a user to reconnect to the terminal server where his disconnected session resides and to resume that session ?
I look araound for the documentation, but I did not find much concerning RDP session load balancing.
Thank you for your inputs
François
9 Replies 9
Gilles Dufour
It all depends what you configured.
Do you have a sticky group ?
What timeout did you configure ?
There is also a default tcp idle timeout of 1h.
Would this be considered *low* ?
This can be changed with a parameter-map.
Gilles.
1/ No, I do not have a sticky group.
2/ I did not configured any timeout.
3/ Yes, 1h is too low (during lunch time, 2 houres would be a minimum)
I configured load balancing exactly like in the manual: "Cisco 4700 Series Application Control Engine Appliance Server Load-Balancing Configuration Guide
August 2008"
Here the output of my configuration:
class-map match-all VIP-STS
2 match virtual-address 10.209.17.100 tcp eq rdp
policy-map type loadbalance rdp first-match VIP-STS-l7slb
class class-default
serverfarm sf-sts
policy-map multi-match int10
class VIP-STS
loadbalance vip inservice
loadbalance policy VIP-STS-l7slb
loadbalance vip icmp-reply active
nat dynamic 20 vlan 20
thank you for your effort.
François
You can increase the idle timeout with the following command :
parameter-map type connection TCP-timeout
set timeout inactivity 10800 (3h)
And apply the parameter-map under
class VIP-STS
With the command
connection advanced-options TCP-timeout
If that does not help, you may have to configure stickyness.
Gilles.
Gilles,
Sorry to piggy-back on this thread. Does "set timeout inactivity" affect sessions terminated on ACE (like HTTP loadbalancing) or also sessions passing through ACE (regular L3 loadbalancing)?
In this example we are talking about L3 loadbalancing, so will this command have an effect, or is sticky timeout the only way in case of L3 sessions?
David
Hello David,
I can not answer your question now, because we only have RDP sessions load balancing.
Changing the "set timeout inactivity 10800" (3h), actually has solved the problem of the RDP sessions been disconnected. But the strange thing is that the session are not disconnected after 3 houres as we could expect. After more than 10 houres the session were still alive !!!
I am going to open a TAC service request to get more information for tunning RDP session...
François
Hi Francois,
Did you receive any feedback from Cisco TAC concerning RDP loadbalancing and this timeout?
Is the timeout of the RDP session linked to the TCP inactivity timeout?
I would be glad to hear some feedback from you concerning this issue.
Dario
it's quite a long time since I had this RDP problem...
We stopped using RDP load balancing because it involved too much HW arround the ACE (see Cisco TAC explanation at the end of the message)
Now we are doing sticky on "Source IP"
There is no really much things to configure and check on the ACE
regarding RDP. Advanced RDP setups usually involve Session Directory
server which inserts routing tokens and ACE load-balances based on
that. Here is a link with more information on that:
http://technet.microsoft.com/en-us/library/cc757253.aspx
Here is another page that explains how the load-balancer works with
RDP. This is not with ACE but the concept is the same:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps780/product_solution_overview0900aecd806fc547.html
So here the "stickiness" is handled and configured on SD. The ACE only
inspects the routing token and modifies its decision based on that.
For this to work you need the "policy-map type loadbalance rdp first-
match ..." part.
This feature is still "under development" and we don't have CLI
commands to control it or to look what is it doing.
Another way of doing it is that you don't have SD and that you do
layer 4 load-balancing of TCP sessions between some RDP servers. Here
configure the above mentioned loadblance policy without the "rdp"
part, and if you can configure for example stickiness based on client
source IP.
This response dated already from January 2009. Many things may have change inbetween......
Ask directly Cisco for news.
François
fsteininger
Finally I got the response frome the Cisco TAC:
I understand you concerns. However, I first need to clarify which
scenario are you running.
match ..." part.
source IP.
==> I decided, since I do not have SD, to go on sourece IP sticky.
Thanks for digging this up from your mailbox :-)
