CSS - Radius authentication problem
Nov 13th, 2008
for a customer we need to configure Radius authentication working like this:
- CSS administrator login to device at user level
- then switch to "enable" mode using a superuser level account.
First login to CSS with a Radius account at user level works fine, but (after enable command) the login at superuser level doesn't work neighter with Radius account nor with local superuser account.
This is the configuration:
radius-server primary secret XXX auth-port 1645
radius-server source-interface
sntp primary-server version 3
date european-date
radius-server secondary secret XXX auth-port 1645
radius-server dead-time 15
radius-server retransmit 15
radius-server timeout 15
virtual authentication primary radius
virtual authentication secondary local
username ZZZ des-password ZZZ superuser
Any idea?
Thanks in advance.
Gilles Dufour Thu, 11/13/2008 - 02:12
is your server correctly configured as described at :
"From the Group Settings section of the Cisco Secure ACS HTML interface, click the IETF RADIUS Attributes, [006] Service-Type checkbox. Then select Administrative. Administrative is required to enable RADIUS authentication for privileged user (SuperUser) connection with the CSS. "
