11-13-2008 03:18 AM
In NetFlow v9, I am not able to see the flow sampler ID in the data flowsets. Am I missing any configuration? However option templates reports the right sampling type and interval and flow sampler id. Is this a bug?
My Cofiguration:
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.118.32 255.255.255.0
ip nbar protocol-discovery
duplex auto
speed auto
flow-sampler nfa
service-policy input sample
service-policy output Stream
interface FastEthernet0/1
description FastEthernet0/1
ip address 192.168.10.90 255.255.255.0
duplex auto
speed auto
flow-sampler nfa
service-policy output sample
cisco2811#sh flow-sampler
Sampler : nfa, id : 1, packets matched : 48811, mode : random sampling mode
sampling interval is : 100
cisco2811#
cisco2811#sh run | incl flow
flow-sampler-map nfa
flow-sampler nfa
flow-sampler nfa
ip flow-export version 9
ip flow-export template options export-stats
ip flow-export template options sampler
ip flow-export template options refresh-rate 1
ip flow-export template refresh-rate 1
ip flow-export destination 192.168.112.152 9996
ip flow-export destination 192.168.112.83 9996
cisco2811#
11-19-2008 02:09 PM
No sampler_id is present in the aggregation template coming from a GSR
Sampling is global on a GSR and as such there's only one sampling rate
for the whole box. GSR netflow DE's decided that no sampler id is needed in that case as the sampling rate in the options data template is the same for all the flows.
The reason that you don't see a sampler_id in the aggregation template is because the sampling on a GSR can only be enabled 'globally' (= the same for the whole box). Why there's a sampler_id in the normal, non-aggregated, templates. That they always fill in '0' in this field and don't use it. To find out the sampling-rate, you can use the options data that is sent by the GSR and apply it to all the flows that are sent from this GSR.
11-19-2008 10:39 PM
Thank you for your reply. Actually there is no one sampling interval for the whole box. We can configure more than one sampler map in the box with various sampling rates to different interfaces. And I can see the sampler ID in the options dataset but not in the data flows. Sampler Id seems to be the unique field to identify the sampling rate itherwise each flow record has to be checked with the entire options flow set with the matching interface information to scale the sampled flows.
