STP disabled on switch
Nov 13th, 2008
Do CISCO switch forwards STP frames between non cisco switches provided the CiSCO switch is disabled with STP.
and these three switches are conected like triangular topology.
Umair
Giuseppe Larosa Thu, 11/13/2008 - 05:16
  • Hall of Fame,
    Founding Member
Hello Umair,
it shouldn't pass STP frames disabling STP, that is not recommended, doesn't make an hub of a switch.
If you need you can use 802.1Q tunneling with layer 2 tunneling and bpdu filter to provide a transparent L2 transport service.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dot1qtnl.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/l2pt.html
Hope to help
Giuseppe
