806 IOS download via xmodem problem
Nov 13th, 2008
Hi all,
I've got a 806 router with two problems :
ROMmon corrupt and a bad IOS for the hardware.
I've resolved the first problem (ROMmon corrupt). I've download by xmodem a new one by the command xmodem -u.
Then, i'm trying to download now a good IOS image by xmodem too with the command "xmodem c806-o3sy6-mz.123-14.T7.bin" with Tera Term. When my router say :"Do not start the sending program yet...
device does not contain a valid magic number
dir: cannot open device "flash:
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c806-o3sy6-mz.123-14.T7.bin" I launch the upload with TeraTerm by : File|transfer|XMODEM|send.
The control panel stay at : Packet# : 128
Bytes transfered :0% and one minute later there is a time out. I don't understand wy the ROMmon image download worked and not for the IOS. Could you help me please.
Thank you by advance.
Pierrick
Giuseppe Larosa Thu, 11/13/2008 - 05:11
Hello Pierrick,
try to use
ROMMON tftpdnld command
as explained in another thread, once you have a working rommon you can do in this way
Hope to help
Giuseppe
pibuskowa Thu, 11/13/2008 - 06:27
Hello Giuseppe,
The tftpdnld is working but i've got this message at the end of the download :
File reception completed.
TFTP flash copy: Invalid file header, copy terminated.
Reason: Wrong target platform OR corrupt file.
I don't understand because it's the good IOS, it's an IOS taken in an another 806...
Any idea ?
Giuseppe Larosa Thu, 11/13/2008 - 09:35
Hello Pierrick,
it looks like your router thinks to be something else or you need to format the flash before trying to write over it.
I would try to format the flash from rommon
Hope to help
Giuseppe
pibuskowa Thu, 11/13/2008 - 09:59
Giuseppe,
How to format flash in rommon?
Normally, when you download an IOS from ftpdnld, the flash is formatted, no?
I've got the same error...
