Conference on CMM
Answered Question
Nov 13th, 2008
Hi everybody,
I configured a CMM module (WS-SVC-CMM-ACT) with CCM ver 4.1.3 as a conference bridge and it are properly registered in the CCM.
When I try to make a conference, I have the message “no conference bridge” on my phone.
The gigabit and fastethernet port are in same vlan on the switch, but only the gigabithe interface have a IP adresse on the CMM.
Any suggestions?
Correct Answer by Sascha Monteiro about 8 years 7 months ago
it's just a host address in your subnet, it knows the default gateway from the config
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a0080837b12.shtml
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 11/13/2008 - 08:33
  • Cisco Employee,
  • Hall of Fame,
    2011
make sure the phone has the HW CFB in it's MRGL so it can access it. either device level or device pool MRGL
java
if this helps, please rate
j.morand Thu, 11/13/2008 - 09:39
no, I only have my hardware CFB in my MRGL and my CFB it's registred.
Sascha Monteiro Thu, 11/13/2008 - 10:33
  • Silver, 250 points or more
you will need to configure an ip-address on the ACT Fast Ethernet interface, with a /32 mask
This interface is used for the RTP streams to the CFB
hth
Sascha
j.morand Thu, 11/13/2008 - 10:40
Hi Sascha,
thanks for your reply.
On the 6500, the gig and fast port are in same vlan. On my CMM card, my int g1/0 have ip 10.0.18.5 255.255.255.0. When I try to configure the fast port with ip on the same vlan 10.0.18.4, I have this error "% 10.0.18.0 overlaps with GigabitEthernet1/0" :)
Sascha Monteiro Thu, 11/13/2008 - 12:09
did you configure 10.0.18.4 255.255.255.255 ??
it needs to be a host address, so /32 mask
j.morand Thu, 11/13/2008 - 12:21
I do not understand. My gig interface have 255.255.255.240 to communicate with default gateway (10.0.18.1). How my fast interface can communicate with CCM if it's configure with /32?
