11-13-2008 07:37 AM - edited 03-11-2019 07:12 AM
We have serveral ASAs installed and adding more. Of course the new boxes have a new version of ASDM. How can I access both the older and newer versions of ASDM?
Thanks Mucho!!!!
Solved! Go to Solution.
11-13-2008 10:30 AM
Here's an example-
Cisco ASDM 6.1(5) is a web-based application to configure and monitor the ASA/PIX security appliance running version 8.0 or 8.1. ASDM 6.1(5)51 is an engineering build based on the ASDM 6.1(5) release.
11-13-2008 10:21 AM
You would have to change the config to point to the one you want.
asdm image disk0:/asdm-613.bin
or
asdm image disk0:/asdm-603.bin
Why not upgrade all the boxes to the latest or a version you're comfortable with?
11-13-2008 10:25 AM
Collin, thanks for your reply! Is the ASDM Image dependent on the version of code that the ASA is running?
11-13-2008 10:27 AM
Yes, you will have to read the release notes. It will tell you which versions are supported.
11-13-2008 10:30 AM
Here's an example-
11-13-2008 10:54 AM
Collin, thanks for your help with this issue!!!
11-13-2008 10:57 AM
No problem.
