abinjola Thu, 11/13/2008 - 23:41
  • Cisco Employee,
hi,
Config synch for SSM modules does not happen, you need to manually configure each module
new_networker Fri, 11/14/2008 - 00:56
Couple more questions
1. Is there a way I can backup the configurations on AIP-SSM1 and restore it onto AIP-SSM2. This will save the manual re-configuration part.
2. Would CiscoWorks or CSM help in configuration synchronization in any way.
cchughes Wed, 01/14/2009 - 14:07
same question here. I could not find a way thru commandline. If there is a way to backup the config I would find that helpful.
adiwakar Tue, 12/09/2008 - 11:45
You cannot sync the configuration between two SSM modules
