CSM - slb-policy not being honored
Nov 13th, 2008
We have a vserver that I set up on a CSM - running v 4.2(9). There is a default serverfarm and an SLB-POLICY that uses an url-map and a different serverfarm. It appears that once the initial connection is made to the default serverfarm any requests that should match the url-map still end up going to that default serverfarm and not the new serverfarm. We are not running persistent rebalance as the application on the default serverfarm will not load the web pages properly. Note there are no sticky configuration parameters with this vserver. Thanks in advance for any help.
aanelso1 Thu, 11/13/2008 - 08:15
P.S. If a url is entered into a new browser that matches the url-map, that request is switched to the correct serverfarm. So to go back and forth between the matched url's and non-matched (default serverfarm) the browser must be closed and and a new one opened (at least this is how Internet Explorer 6 is responding).
