Multiple extensions, single translation pattern
Answered Question
Nov 13th, 2008
All,
I have two 7905 IP phones with their own extensions. If I have a DID I'm forwarding to one phone with a translation pattern, what's the best way to get it to ring on the second phone without having to match their extensions?
I was thinking a Line Group and Hunt List combination might be a place to start, but I'm not having much luck with it.
TIA
Correct Answer by jbarcena about 8 years 5 months ago
Well a Line Group will be fine. Just set your TP to the Hunt Pilot instead of the actual extension and then put on the Line Group both extensions.
//Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
jbarcena Thu, 11/13/2008 - 08:39
  • Red, 2250 points or more
//Jorge
