CSM error when adding IDSM-2
Nov 13th, 2008
I get the following error when trying to add an IDSM-2 blades to CSM:
"Invalid device: Could not deduce the SysObjId for the platform type
WS-SVC-IDSM-2"
I have successfully added another IDSM-2 blade running the same vesion.
The version is:
sensor# sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 6.2(1)E3
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S365.0 2008-10-31
Virus Update V1.4 2007-03-02
OS Version: 2.4.30-IDS-smp-bigphys
Platform: WS-SVC-IDSM-2
Serial Number: SAD09200865
No license present
Sensor up-time is 15 min.
Using 1410576384 out of 1983508480 bytes of available memory (71% usage) application-data is using 41.6M out of 166.8M bytes of available disk space (26%
usage)
boot is using 39.7M out of 68.6M bytes of available disk space (61% usage) application-log is using 529.7M out of 2.8G bytes of available disk space (20% u
sage)
MainApp E-2008_OCT_16_16_24 (Release) 2008-10-16T16:40:57-0500 Ru
nning
AnalysisEngine E-2008_OCT_16_16_24 (Release) 2008-10-16T16:40:57-0500 Ru
nning
CLI E-2008_OCT_16_16_24 (Release) 2008-10-16T16:40:57-0500
Upgrade History:
IPS-K9-6.2-1-E3 16:24:00 UTC Thu Oct 16 2008
Maintenance Partition Version 2.1(2)
Recovery Partition Version 1.1 - 6.2(1)E3
Host Certificate Valid from: 12-Nov-2008 to 13-Nov-2010
sensor#
hadbou Wed, 11/19/2008 - 09:32
  • Bronze, 100 points or more
think that you might be hitting the bug id CSCsm72131.This error message is given when CSM user attempts to Add an IDS/IPS device or Discover Policies on an IDS/IPS device whose platform string changed in IPS software 6.0(4)E1. Or, CSM user attempts to Add a device or Discover Policies on a device whose platform string is not supported by CSM.
Replace the original VMS-SysObjID.xml file ( by default located in the C:\Program Files\CSCOpx\MDC\athena\config\ directory) with the attached (updated)
VMS-SysObjID.xml file. Afterwards, restart the 'Cisco Security Manager Daemon
Manager' service (CRMDmgtd), and re-try adding or discovering the affected
device(s) again.
