Cisco Discovery Tool - IP PHONE
Nov 13th, 2008
Hello
Has anyone discovered IP PHONES using CDT??
and what SNMP to use for the discovery?
I tried the discovery using "public" snmp and couldn't discover any IP PHONE.
drolemc Thu, 11/20/2008 - 14:42
You can disable or enable Cisco Discovery Protocol (CDP). CDP allows the phone to be discovered by the CiscoWorks network management system. IP Phones cannot be simply discovered as they do not have SNMP. However, Call Manager support both CDP/SNMP which can be discovered if it is configured correctly. Once Call Manager is discovered, IP Phone table can be discovered in UT assuming Call Manager has all the correct IP Phone info (Detailed Call Records/History). You will need to work with your Call Manager people to figure how to configure Call Manager correctly. Cisco Discovery Protocol (CDP) is a device-discovery protocol that runs on all Cisco-manufactured equipment. Using CDP, a device can advertise its existence to other devices and receive information about other devices in the network.
