Suggestions for high density client areas
I've had a request to provide classroom wireless access - on the order of 150 laptops in a room taking online exams. We have boxes of 1230s and a nice 4402 WLC but that all seems a bit inadequate to handle this request. There is a single 1230 in this particular room (of 4 in the building) and I'm going to add two more to the room with some wall mount flat antennas but I don't think that's going to get 'er all done. And there's another class room that will likley get the 1/2 or better of the same load and it's only about 60' away. It'll be all about G radios because I'm sure none of these students (or a very small percentage) have N equipment. Any suggestions would be appreciated.
tkhan Thu, 11/13/2008 - 12:25
Use 1240AGs, dual radios. I have lots of training rooms and found that 3 dual band radio APs in the coverage area were adequate. It all depends on the nature of the traffic, ie. bandwidth per trainee used.
ericgarnel Fri, 11/14/2008 - 07:13
We deal with this a lot. Radio placement is key. You can use "bags of water" - people to help with signal containment. If you build zones for 2.4 and keep your radios low, you can accommodate a lot more people in a given area. You can also backfill with some 802.11a only radios as well to a certain degree.
We use a combination of 1252s and 1242s.
The 1252s are nice for sheer performance and the 1242s are nice for directional signal. We have seen the 1242s handle large loads as well.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
