Missed call information with Expansion module
Nov 13th, 2008
We have two admins with an expansion module that share the same DNs of executives in the office. When someone calls an executive and they don't answer the admins see a missed call. One of the admins can go to Directories | missed calls and see the call detail From "phone number" for "Executive A" but the other admin only sees "From "Phone number" and not who it was intended for so she gets confused if the call was intended for her or someone else. I looked at both phones and don't see any differences.
Overall Rating: 3 (1 ratings)
Rob Huffman Thu, 11/13/2008 - 10:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chris,
Is it possible that these are two different IP Phone models? Like perhaps a 7960 and a 7961? The older models like the 7960 do not show the detail that the 3rd generation models like the 7961 do.
Just a thought,
Rob
CHRIS KALETH Thu, 11/13/2008 - 11:17
I noticed the two phones are different images (both are 7961G).
I tried upgrading the phone that is not working but it keeps the same image.
This phone works
App Load ID Jar41sccp.8-2-1ES5.sbn
Boot Load ID 7961G_64-02070631Amd64megRel.bin
Version SCCP41.8-2-1ES5S
Expansion Module 1 S00105000300
This phone does not work
App Load ID Jar41.2-9-2-26.sbn
Version 7.0(3.0S)
Rob Huffman Thu, 11/13/2008 - 12:36
  • Hall of Fame,
    Founding Member
Hi Chris,
Well, I guess that's where the problem lies. Whta we need to find out is why the second phone won't upgrade to the newer firmware? If you watch the phone when it boots up can you see where this upgrade fails by the message on the screen of the phone? If not perhaps you can setup a sniffer to get some traces of the boot/tftp sequence.
Rob
CHRIS KALETH Thu, 11/13/2008 - 12:37
Thanks Rob. I copied TFTP locally to that phone and I got it upgraded. I'm just waiting for a response from the user, but I'm sure it will be working now. Thanks.
Rob Huffman Thu, 11/13/2008 - 13:21
  • Hall of Fame,
    Founding Member
Hi Chris,
Nice work! I'm quite sure that this will resolve the issue.
Cheers!
Rob
