ASA v8 options for Remote Desktop (RDP)
Nov 13th, 2008
We recently purchased an ASA5520, including some WebVPN licenses.
I need to give our employees access to their desktops, using the Microsoft RDP protocol.
It seems I have a lot of options for how to do that. The first one I've tested is the web based RDP java plugin that Cisco provides. It works well, but I'm not sure I like the java RDP interfaces.
If I wanted to switch to using the Microsoft RDP client, what would my options be?
I know I could use the SSL VPN Client, and then use RDP through that. But that seems like a little bit of overkill.
I don't really understand the Port Forwarding or Smart Tunnels options. Would those be a valid option?
Thanks for the replies,
Shane
