RSP720 - etherchannel
Nov 13th, 2008
We are facing problems with etherchannel on 7609/RSP720/SRC
Etherchannel between ports on X6724 cards OK. We have 2 portchannels running on this card
Etherchannel2 with member port 5/1 and 6/1 are not working stable. Configuration OK, some traffic coming but not stable.
Test1: ping, some OK but most are missing.
Test2: OSPF, debugging OSPF shows states down, 2way, exchange on both sides. (never full)
Any known issues with using RSP720 ports as etherchannel?
Jon
tstanik Wed, 11/19/2008 - 07:17
  • Bronze, 100 points or more
Traffic will be impacted if the supervisor port goes down as part of switchover and the duration of this outage depends on the time it takes to bring up the newly standby supervisor and its ports.
Here is the URL for the Configuring EtherChannels it may help you
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/channel.html
