Outbound H.323 calls failing with Cause Value=47
Nov 13th, 2008
Scenario:
User lifts handset dial number (local, LD, Int, toll free, doesn't matter) and hears a fast busy. User hangs up, lifts handset dials same number and call processes normally.
Call Manager version 4.2(3)sr4b
ISR Gateway Cisco 3845 12.4(15)T3
I belive this has something to do with my dspfarm configuration, see below.
pxcrahrt1#sh run | sec dspfarm
dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 13
associate application SCCP
dspfarm profile 2 conference
description NM-DSPFARM Conference Bridge
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 3 mtp
description MTP resources for SIP trunks
codec g711ulaw
maximum sessions hardware 40
Overall Rating: 5 (1 ratings)
jbarcena Thu, 11/13/2008 - 14:22
  • Red, 2250 points or more
47 = Resources unavailable, unspecified
The requested channel or service is unavailable for an unknown reason. This might be a temporary problem.
What type of connection are you using? T1 CAS, PRI, E1?
Cdbakken1 Thu, 11/20/2008 - 14:21
This issue was requested by reallocating the available DSP resources.
Cdbakken1 Thu, 11/20/2008 - 14:24
This issue was CORRECTED by reallocating the available DSP resources.
eoinwhite Thu, 01/29/2009 - 05:01
Im seeing the same issue over 4 BRIs. What was wrong with your DSP config and what did you change to fix.
