Fax Gateway for Callmanger Integration
Nov 13th, 2008
What is the best gateway to use for analog fax machines that will integrate with callmanager? Is it best just to use a 2800 or 3800 router with analog fxs ports, or is there a better device to use for this? I am looking at somewhere in the range of 48-72 fax machines.
Overall Rating: 4 (1 ratings)
allan.thomas Fri, 11/14/2008 - 09:17
  • Blue, 1500 points or more
The VG224 would be appropriate if you are consolidating multiple analogue devices.
The following link describes configuring FXS modules with MGCP.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
The following document link is for the VG224 product guide:-
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/ps5516/product_data_sheet09186a00801d87f6.html
Hope this helps.
Allan.
Pls rate helpful posts.
