ASR - IPSEC, GRE, channel group, and MTU Questions
Nov 13th, 2008
I have an ASR1004 and am trying to load-balance a 1.5G data rate over two 1-Gig ports using IPSEC ports, but I have a few questions.
1. Can GRE support a 9K mtu
2. Can you run IPSEC on a channel-group
3. Can the ASR load-balance per- S&D on a channel-group?
I currently have two separate tunnels, one on each outbound gig link with OSPF running. However, I can't get a 7000 mtu w/ the DF bit set through to the distant end. I am guessing this is because of the GRE interface.
So is it possible to run IPSEC on a channel-group and have this load balance per S&D? I need to use the BW of both ports.
Thanks for the help!
owillins Wed, 11/19/2008 - 11:20
The ASR1004 router we can only send packets with a maximum MTU size of 1438 Bytes over the encrypted tunnel.
