SW-CCME-UL-3911 CallManager Express License For 3911
Nov 13th, 2008
Hi all, I have ordered a few of the above named licenses, (SW-CCME-UL-3911), however, I do not believe I have received them. In the boxes that the 3911 phones came in I was given a "Regulatory Compliance and Safety Information for Cisco Unified IP Phones" manual, "Cisco 90-Day Limited Hardware Warranty Terms" document and an "End User License Argeement".
What I was wanting to know is, is the SW-CCME-UL-3911 license supposed to be printed on a separate piece of paper or is it built into the phone?
Thank you all in advance.
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 11/14/2008 - 07:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Will,
In this case the license is "honor based" and is indicated in the PO/Part# you correctly ordered. You will not receive a seperate license so you should be good to go :)
Hope this helps!
Rob
voiper_99 Sun, 11/16/2008 - 14:10
Hi Rob, thanks a lot for the information :)
Cheers
Will
