BGP triggered blackholing within MPLS VPN
Nov 13th, 2008
I have a MPLS L3 VPN setup.
CE1--PE1-----PE2--CE2. The client advertises advertises its routes through BGP to the PE which includes a supernet of PE-CE connected interface. This makes PE1 connected interface IP reachable from CE2. The inbound ACL on the PEs doesnot help as we cannot restrict a valid client subnet.
I am planning to create a BGP triggerd blackhole in the PEs for the other PE connected interface. This way even if a packet from CE2 for PE1-CE1 connecting IP for PE1 enters my network it will be dropped in PE2.
Client Supernet : 20.1.1.0/24
PE1-CE1 connecting subnet 20.1.1.0/30
PE1 related config:
address-family ipv4 vrf Kiran_Test
neighbor 20.1.1.2 remote-as 12644
neighbor 20.1.1.2 activate
no auto-summary
no synchronization
bgp dampening 1
network 20.1.1.0 mask 255.255.255.252 route-map test_ashish
exit-address-family
route-map test_ashish permit 10
set ip next-hop 1.1.1.1
set community 0:100
ip route vrf Kiran_Test 1.1.1.1 255.255.255.255 Null0
!this route is used to blackhole the traffic.
I have the same static blackholing route in PE2 also
PE2#sh ip route vrf Kiran_Test
Routing Table: Kiran_Test
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 3 subnets
S 1.1.1.1 is directly connected, Null0
B 1.1.25.252 [20/0] via 10.1.2.2, 16:27:04
B 1.1.25.254 [20/0] via 10.1.2.2, 16:27:04
50.0.0.0/32 is subnetted, 1 subnets
B 50.50.25.160 [20/0] via 10.1.2.2, 16:27:04
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 20.1.1.0/30 [200/0] via 212.31.220.69, 14:04:42
B 20.1.1.0/24 [200/0] via 212.31.220.69, 14:17:46
The problem is that the next hop is not changing to 1.1.1.1 in the BGP updates received at PE2. The route-map set in PE1 is working though as I can see the metric I am setting thare is getting reflected in PE2 but the next hop doesnot change.
PE2#sh ip bgp all community 0:100
For address family: IPv4 Unicast
For address family: IPv6 Unicast
For address family: IPv4 Tunnel
For address family: IPv4 MDT
For address family: VPNv4 Unicast
BGP table version is 143798759, local router ID is 212.31.220.14
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 12641:900012 (default for vrf Kiran_Test)
* i20.1.1.0/30 212.31.220.69 0 100 0 i
*>i 212.31.220.69 0 100 0 i
For address family: IPv4 Multicast
For address family: IPv6 Multicast
PE2#
Is this because of an IBGP update where the nest hop remains unchanged? Can we tweeak it somehow? Please let me know if you have any other solutions on how to make it work.
regards
Ashish
Overall Rating: 5 (1 ratings)
marikakis Fri, 11/14/2008 - 02:49
  • Gold, 750 points or more
In standard BGP, an eBGP speaker advertises externally received routes to all internal neighbors without changing the external next-hop. In this scenario, if you do not want to advertise external link addresses on the inside, you need to use next-hop-self.
In the MPLS/VPN environment things are different. Each PE will advertise by default itself as the next-hop for routes it sends to MP-iBGP neighbors. This is done so that packets can be label switched to a PE that has knowledge of the VPN label (PE is endpoint of LSP for VPN destination). The address used by the PE is the address specified in update-source for the MP-iBGP session with neighbor.
So, I think you are setting the next-hop in the ipv4 vrf BGP address-family before those routes get automatically redistributed into MP-iBGP. When they do, redistribution changes the next-hop from what you had set it, to the local PE address and advertises route to remote PE.
Applying a route-map in the vpnv4 session of PE1 towards PE2 (out direction) for the specific route might fix your issue. If all fails, you could blackhole on PE2 the PE1-CE1 link route with a static route on PE2 for the /30 pointing directly to null0 (although this is not very scalable if you need a solution used often, it could be a temporary quick fix).
Kind Regards,
M.
p.s. Remember to take additional measures (e.g. no-export keyword or other filters) when setting community for blackholing purposes, to avoid blackholing youtube or something (it has happened in the past, it can happen to any good (address-)family). If circumstances allow, you could end up advertising the blackhole route towards CE1 or some other router.
