Site to Site IPSec tunnel issue
Nov 13th, 2008
I have established a IPSec tunnel between India and Brazil,
(india)ASA <--> VPN Concentrator (Brazil)
tunnel works 52 mins and then tears down,
automatically it will renegotiate and form the tunnel after 8 mins...
what could be the isse?
risenshine4th Mon, 11/17/2008 - 11:41
This appears to be a timing issue.
Are the rekey values set to 3600 secs or 1 hour?
If this is the case the traffic is normal however the NTP or Clock times on each end are off by 8 minutes.
One solution is to use the same NTP server. The other would be to manually adjust if possible.
