Difference between DHCP relay & DHCP IP helper address
Nov 13th, 2008
Hi Guys,
Can anyone please explain what is the difference between DHCP relay & DHCP IP helper address? Or please give me any useful URL for both of these.
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 11/13/2008 - 22:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Murad
A DHCP relay agent is any device that forwards DHCP packets between a client and a DHCP server. Cisco routers can act as DHCP relay agents and the way you tell them to do this is to configure the "ip helper-address " under the router interfaces.
So the ip helper-address is simply the way Cisco implements the DHCP relay function on it's routers.
Jon
