11-13-2008 10:05 PM - edited 03-04-2019 12:19 AM
Hi, this is my first time to configure routers and switch. Anyone who can assist me of the basic configuration I should implement with my connections? I have attached the diagram with labels for interface ip address assignments. The only thing I need is I can access the two servers (1&2). Also, to remote manage the R1&2 and S1. How to change username during authentication? Thanks!
Solved! Go to Solution.
11-14-2008 05:33 AM
Hello Oliver,
based on your drawing:
switch:
! to create vlan2
vlan 2
! associate to ports
int f0/1
switchport
switchport access vlan 2
int f0/2
switchport
int f0/3
switchport
interface Vlan2
ip address 10.205.20.100 255.255.255.240
no shut
ip default-gateway 10.205.20.97
R1
int gi0/2
ip address 10.205.20.97 255.255.255.240
no shut
int gi0/1
ip address 10.205.28.18 255.255.255.252
ip routing
ip route 0.0.0.0 0.0.0.0 10.205.28.17
R2
ip routing
int gi0/1
ip address 10.205.28.17 255.255.255.252
ip route 10.205.20.96 255.255.255.240 10.205.28.18
authentication
add
username newuser password newpassword
have
line vty 0 4
login local
Hope to help
Giuseppe
11-14-2008 05:33 AM
Hello Oliver,
switch:
! to create vlan2
vlan 2
int f0/1
switchport
int f0/2
switchport
int f0/3
switchport
interface Vlan2
no shut
R1
int gi0/2
no shut
int gi0/1
ip routing
R2
ip routing
int gi0/1
authentication
add
have
line vty 0 4
login local
Hope to help
Giuseppe
11-15-2008 06:38 AM
Thanks a million!
