Cisco 2811 not going ahead from Switch:
Answered Question
Router Details :
model number Cisco 2811
With switch model detail- NME-16ES-1G-P
PROBLEM FACING:
once if you switch from router to switch its showing as
Switch :
Correct Answer by royalblues about 8 years 7 months ago
To download an image you need a valid Cisco contract which i think you have.
The EtherSwitch service modules support the same Cisco IOS Software images as the Catalyst 3750 and Catalyst 3750-E Series Switches
YOu can download the image to the router flash and then do an xmodem to transfer it to the ether switch module.
Have a look at the software section in the below link
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd8028d16a_ps5855_Products_Q_and_A_Item.html
Narayan
Overall Rating: 5 (1 ratings)
Want to ask you following question:
Is the ether switch module image/IOS loaded in the same flash where router image/IOS is loaded.
How can I download the image from the cisco link?
Could you provide me the ether switch image name specific to 2811 router.
I have already tried downloading the correct image from the Cisco site using software advisor, but couldn't find the correct image.
Pls Help
Rgds,
Ashish
Correct Answer
royalblues Mon, 11/17/2008 - 22:32
  • Green, 3000 points or more
Narayan
royalblues Mon, 11/17/2008 - 22:57
yes (above 12.2(25)EZ) as long as you have a valid Cisco contract..
Narayan
