ASA 7.2 5510 portmap translation creation failed for tcp src inside
Answered Question
Hi ive got a NAT problem, the asa shows up a the error: "portmap translation creation failed for tcp src inside" when trying to access a specific lan, here are the network config
INSIDE is 10.21.0.0/24
OUTSIDE is xx.xx.xx.xx
TEMPNET is 192.168.0.0 > NET behind tempnet is 172.1.1.0 /24
The Problem is i have only 2 IPs i can use in Tempnet, so i have to NAT all my internal IPs to 1 IP from the TEMPNET, TEMPNet is provided by another company and got its own router which forwards pakets into several foreign networks, to prevent routing issues (tempnet routers dont know routes into my local net) i need to nat all my local ips to lets say 192.168.1.1.
I added a route for example route tempnet 172.1.1.0 /24 192.168.1.2 (1.2 is the router from the TEMPNET).
Now here are my nat / global / statements:
access-list NAT_TEMP permit ip 10.0.21.0 255.255.255.0 172.1.1.0 255.255.255.0
access-list NAT_ANYDESTINATION permit ip 10.0.21.0 255.255.255.0 any
nat (inside) 1 access-list NAT_ANYDESTINATION
nat (inside) 2 access-list NAT_TEMP
global (inside) 1 interface
global (tempnet) 2 interface
when trying to access 172.1.1.1 i receive the errorcode: portmap translation creation failed..
when i change this:
no nat (inside) 2 access-list NAT_TEMP
no global (tempnet) 2 interface
global (tempnet) 1 interface
it works like a charm, but why isnt it working with the other config, lets say i want to split it more up and work with more then 1 nat rules based on source and destination it wont work, why do i cannot use multiple nat/global statements?
Correct Answer by Jon Marshall about 8 years 4 months ago
Peter
This link suggests that it is the order that is important -
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/s.html#wp1026694
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 11/14/2008 - 03:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Peter
Try swapping your nat statements around. I think the problem you face is that the firewall runs through the nat (inside) id access-list statements in order. And because
is the first statement this also matches any traffic going from 10.0.21.0 -> 172.1.1.0. So try this
nat (inside) 1 access-list NAT_TEMP
nat (inside) 2 access-list NAT_ANYDESTINATION
Jon
