Routing between Token Ring and Ethernet
Nov 14th, 2008
Hello Experts,
I have a Cisco 3825 (revision 1.2) with 225280K/36864K bytes of memory running "flash:c3825-spservicesk9-mz.124-3g.bin".
There are VLANs configured on the router and each port on its respective VLAN connects to its own Layer 2 switch.
I am trying to get the routing between a token ring PC and one of the ethernet PCs.
Both the PCs are able to ping their Default gateways. Token ring PC is able to ping the Ethernet Interface address but not the PC on the VLAN.
I would greatly appreciate if one of you could please help me out here.
Config below -
Building configuration...
Current configuration : 2212 bytes
version 12.4
hostname RouterA
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
resource policy
no network-clock-participate slot 1
ip subnet-zero
ip cef
voice-card 0
no dspfarm
interface Loopback0
ip address 2.33.209.5 255.255.255.255
interface GigabitEthernet0/0
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
interface FastEthernet0/1/0
description ** Server Subnet **
switchport access vlan 2
interface FastEthernet0/1/1
description ** Token Ring **
switchport access vlan 3
interface FastEthernet0/1/2
interface FastEthernet0/1/3
description Core-Switch
switchport access vlan 4
interface Serial0/0/0
ip address 2.33.236.17 255.255.255.252
encapsulation frame-relay
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface TokenRing1/0
ip address 172.25.148.1 255.255.252.0
ring-speed 16
interface Vlan1
no ip address
interface Vlan2
ip address 172.25.232.3 255.255.252.0
standby 2 ip 172.25.232.1
standby 2 timers msec 500 1
standby 2 priority 110
standby 2 preempt
interface Vlan3
description ** Firewall **
ip address 172.25.236.3 255.255.255.0
standby 3 ip 172.25.236.1
standby 3 timers msec 500 1
standby 3 priority 110
standby 3 preempt
interface Vlan4
desc Core-Switch
ip address 172.25.238.3 255.255.255.0
standby 4 ip 172.25.238.1
standby 4 timers msec 500 1
standby 4 priority 110
standby 4 preempt
router bgp 65012
no synchronization
bgp log-neighbor-changes
timers bgp 10 30
redistribute connected
neighbor 2.33.236.18 remote-as 5462
neighbor 2.33.236.18 soft-reconfiguration inbound
no auto-summary
ip classless
ip http server
no ip http secure-server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Many thanks,
Arav
Richard Burts Fri, 11/14/2008 - 05:15
Arav
You tell us that: "Token ring PC is able to ping the Ethernet Interface address". Can you also do that same type of test for the Ethernet PC, can the Ethernet PC ping the Token Ring interface address?
Rick
aravindhs Fri, 11/14/2008 - 06:35
Thank you very much for your reply, Rick.
The customer has replied with the following -
none of the Ethernet subnets can ping the token ring subnet, however the token ring subnet can ping all of the ethernet subnets!
One other thing I noticed was that even though I could ping the gateway address of all the Ethernet subnets (232.1, 236.1 & 238.1) from the token ring subnet, I couldn't ping the PC address (232.50 for example).
So, I have requested for a more detailed explanation of this. Once i get a response, I shall post it back here. Looking forward to your help here.
Kind Regards
arav
aravindhs Fri, 11/14/2008 - 07:09
Hi Rick,
These are the results -
Pinging from the Token Ring PC, I can ping the Ethernet gateways, just not the PC connected to any of them.
Pinging from the Ethernet PC, I can't ping the Token Ring interface.
Harold Ritter Fri, 11/14/2008 - 07:14
Arav,
Is there a default gateway configured on the Ethernet connected PC?
aravindhs Fri, 11/14/2008 - 07:23
Hi Harold,
The default gateways are configured on the PC and the customer has confirmed that it is correct.
I have never done TokenRing before nor could I find any relevant documents to sort this out.
Many thanks for all your help. Looking forward to your help to get this working.
Many thanks
Arav
Richard Burts Fri, 11/14/2008 - 10:27
Arav
One of the nice things about routing IP at layer 3 is that IP is not dependent on any layer 2 things (which is where Token Ring and Ethernet are different). So from an IP routing standpoint it no different routing to Token Ring or routing to Ethernet.
The symptoms suggest that either the default gateway on the Ethernet is not really correct or that there is some kind of access list or other filtering that is preventing the traffic. I would suggest that you ask that they provide the output of ipconfig (or other appropriate command if the device is not Windows) from both the Ethernet PC and the Token Ring PC.
Rick
aravindhs Wed, 11/19/2008 - 09:01
Hi Rick
Please find the outputs of the ipconfig screen and some debug and show arp outputs from the router.
Many thanks
Arav
Richard Burts Wed, 11/19/2008 - 11:29
Arav
Thank you for the additional information. It does show that both PCs do seem to have correct default gateways configured, which was one of my theories.
I wonder if the issue might be a firewall on the Ethernet PC at 172.25.232.50. Is it possible that the PC does not accept ping? If you just do a standard ping from the router to the PC does it respond?
Rick
aravindhs Thu, 11/20/2008 - 01:40
Hi Rick,Many thanks for your quick rply.
Please find some ping outputs sourced from its own interface IP and from each other.
HART-WA01-RH1#ping 172.25.232.50
Sending 5, 100-byte ICMP Echos to 172.25.232.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
HART-WA01-RH1#ping 172.25.148.47
Sending 5, 100-byte ICMP Echos to 172.25.148.47, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
HART-WA01-RH1#ping 172.25.148.47 so vl2
Packet sent with a source address of 172.25.232.1
HART-WA01-RH1#ping 172.25.232.50 so tok1/0
Packet sent with a source address of 172.25.148.1
Success rate is 0 percent (0/5)
interface Vlan2
ip address 172.25.232.1 255.255.255.0
end
ring-speed 16
end
Many thanks, Arav
Richard Burts Thu, 11/20/2008 - 04:35
Arav
Thanks for the additional information which I asked for. It certainly shows that it is not an issue with a firewall preventing pings. What happens if you do ping sourced from vlan 3 or from vlan 4?
I also wonder if you could post the output of route print from the Ethernet PC.
Rick
aravindhs Fri, 01/02/2009 - 02:34
Hi Rick
Happy new year to you and everyone from our forum !Apologies for the late reply ! But the problem is fixed ! Thanks for all your help. Please find the config -
Source-Route Translational Bridging (SR/TLB))
source-bridge ring-group 10
source-bridge transparent 10 11 1 1
description ** To 232 Subnet **
ring-speed 16
source-bridge 1 1 10
source-bridge spanning
interface Vlan2
ip address 172.25.232.3 255.255.255.0
standby 2 preempt
bridge-group 1
bridge 1 protocol dec
bridge 1 bitswap-layer3-addresses
Arav
Richard Burts Fri, 01/02/2009 - 04:59
Arav
I am glad that you found a solution for the problem. Thannk you for posting back to this thread and indicating that the problem was solved and how you solved it. It helps make the forum more useful when people can see that a problem has been resolved.
Rick
