Site to Site VPN with IOS to Checkpoint - I'm lost
Nov 14th, 2008
Hi all,
I need to setup a site 2 site IKE VPN-tunnel, the configuration kinda speaks for itself, but in short the idea is to only use the secondairy DSL interface for a dedicated IPSec tunnel to a remote location.
When the tunnel is being initiated, it fails on Phase1:
The awkward thing is:
ISAKMP: reserved not zero on ID payload!
%CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from 111.111.111.111 failed its sanity check or is malformed
Would indicate a mismatch in the preshared key (or does it?!). I tripple checked that....
Kinda lost now, any thinking along and/or help appreciated!
ajagadee Fri, 11/14/2008 - 08:26
  • Cisco Employee,
Yes, the debug message "ISAKMP: reserved not zero on ID payload!" means that the PSK does not match on both the sides.
Also, can you add the "no-xauth" option to the PSK Statement in the Configuration.
crypto isakmp key cisco address 1.1.1.1 no-xauth
Arul
*Pls rate if it helps*
keesvanbeekict Wed, 11/19/2008 - 01:29
It'll probably won't be earlier than this friday than I can give it a try, but I will and report/rate back ;-)
I'm not sure why using the no-xauth would make a difference though...
"no-xauth:
(Optional) Use this keyword if router-to-router IPSec is on the same crypto map as a Virtual Private Network (VPN)-client-to-Cisco-IOS IPSec. This keyword prevents the router from prompting the peer for extended authentication (Xauth) information (username and password). "
Worth a shot :-)
