correct IOS Version Catalyst 6513
Nov 14th, 2008
i want to update a 6513, where an IOS Package "Enterprise LAN Only(s72033-ps-mz.122-18.SXD3.bin)" works.
Which is the appropriate package? Enterprise Base?
Edison Ortiz Fri, 11/14/2008 - 08:34
  • Hall of Fame,
    Founding Member
The closest match would be Enterprise Base but I highly suggest you head to http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and compare the Software Images so you can learn what features you may be losing or gaining when moving from one package to another.
HTH,
__
Edison.
schmidta Sun, 11/16/2008 - 23:55
Thank you for your answer, but this not my problem. I don't want make any mistake in the sight of licensing. In my first message i pasted an image from LAN ONLY Feature.
The orginal image was "c6sup22-js-mz.121-13.E3.bin" installed on SUP2/MSFC2. Now the Supervisors are SUP720 with a LAN ONLY IOS and i want to update to the correct Feature Package. So with your link i can't find the correct package, which i used for an allowed update ( software support).
Edison Ortiz Mon, 11/17/2008 - 04:39
  • Hall of Fame,
    Founding Member
c6sup22-js-mz.121-13.E3.bin is Enterprise LAN Only and if you want to maintain the same level of license w/ Sup720 and latest IOS code, the Feature Set would be "Enterprise Services SSH".
In your original post, you mentioned s72033-ps-mz.122-18.SXD3.bin which is IP Only and the similar package will be IP Services.
HTH,
__
Edison.
