CSA: How to properly backup the CSA Client Installation on a user pc?
Nov 14th, 2008
coming from the backup side of things my question is: "How to successfully backup the csa client files on a pc?"
Currently when running the nightly backup i am running into the problem that access to certain csa files is denied.
E.g.:
11/11/2008 03:01:04 ANS1228E Sending of object '\\pc06\c$\Programme\Cisco Systems\CSAgent\cfg\agent-api.orl' failed
11/11/2008 03:01:04 ANS4007E Error processing '\\pc06\c$\Programme\Cisco Systems\CSAgent\cfg\agent-api.orl': access to the object is denied
11/11/2008 03:01:04 ANS1228E Sending of object '\\pc06\c$\Programme\Cisco Systems\CSAgent\cfg\agent-com.orl' failed
11/11/2008 03:01:04 ANS4007E Error processing '\\pc06\c$\Programme\Cisco Systems\CSAgent\cfg\agent-com.orl': access to the object is denied
and like 20 more files.
Whats the proper way to backup a client including csa. Obviously i can't make my TSM client shutdown the service and then fill out the captcha which protects it.
What would be the correct way to configure CSA properly to allow us to make a backup of the full machine. I guess we are not the only ones backing up full systems. ;)
Thanks in advance for any hints.
Best regards,
Eike
matt_nels Fri, 11/14/2008 - 12:10
I would start by looking at your policy/rule modules to see what is blocking the backup process to "backup" those files.
If your CSA policy is actually doing the blocking, you should be able to create the exception(s) to give the process/user/etc. the ability to access the CSA agent files for backup.
Depending on the CSA policy you are running, the CSA agent protects itself from attack.
johuston Wed, 11/19/2008 - 19:36
Eike,
What is the benefit to backing up CSA on the endpoint? All the configuration is stored on the MC and will be downloaded when the agent came back online after a restore. Typically customers will exclude the CSA directories from a full backup to avoid these conflicts.
Josh
ela___2008 Thu, 11/27/2008 - 23:28
Josh, you are correct. That makes sense. We have indeed excluded the csa now.
Only reason could possibly be to restore a system with as less manual activities required as possible. (in case one backs up with systemstate) :)
